User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I'd like an option to the 'value' property (especially for clusters) to enable/disable showing the parent.
In the example below, I'd like to toggle whether the parent is shown on the default label when I create the value property from filename (hide parent) to old datum: filename (show parent)...
It would be nice not only to be able to toggle this for specific instances, but also to be able to set the default as a VI property (and a project property).
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
