NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
tst
Add "Add Element" and "Remove Element" to the Index Array context menu
Status: New
by Knight of NI on ‎10-23-2009 07:12 AM
Some resizable primitives (Build Array, Compound Arithmetic) have an option in their right click menu which allows you to add or remove elements:
The Index Array primitive is notably absent from that list. It would be very useful if we could add or remove elements like this:
Comments
by Active Participant elset191 on ‎10-23-2009 01:43 PM
One thing I would change from your gif is to add the input where you right clicked.  I believe most of the other ones behave this way.  (If I'm just making that up, then they should behave that way too.)
by Knight of NI on ‎10-24-2009 01:16 PM
That is exactly what the animation shows. The bottom row was moved one down because a row was added in the middle. Note that the wires themselves are bent because the entire row was moved down.
If you remove a row which has something wired into it, those wires will break, similar to how it works today on the other resizable nodes.
P.S. I didn't check, but this might also be relevant to the other resizable nodes in the array palette.
P.P.S. The example animation says "add input", but I feel that it should actually add a full row (like the animation shows). There is an argument for adding either an input or an output, depending on where you clicked, but I feel that use case is rarer.
by Active Participant elset191 on ‎10-26-2009 09:06 AM
Oops, I didn't see the bend in the wire.
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
132
87
71
65
59
