If the VI terminal is having 'Find Control' option lie Add Terminal, Remove Terminal then it would be easy to find the Controls which is located in the front panel.
Senthil Prakash S Certified LabVIEW Associate Developer
In the VI connector pane in each connector there is a control or indicator associated(if it is connected), they say if connector pane is having 25 connectors which is connected with 25 controls or indicator, in that we cannot able to find where the control or indicator really located in front panel since it may be hidden or something.
The Picture shows Find Control/Indicator selection show user can fnd the item easily or otherwise double click on terminal to find the control or indicator. Now only Selection of Control and Indicator if we click on the connector pane items or other
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Connector-pane-double-click-terminal-jumps-to-control/...
