About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Add an option to enable setting the front panel/ block diagram default opening position in VI Properties --> Window Appearance
Whenever I have a couple of VIs open I drag and arrange them around the screen (/screens) for better visibility. I think it would be great if there was a way to have LabVIEW open the VIs at a specified position on the screen and not necessarily the last open position. (This would be useful while development especially if one plans to share these VIs with others.)
4 Comments
Knight of NI Knight of NI
Knight of NI
The VI Windows don't open at the last open position. They open (or at least try to) at the position they were when they were saved. As long as no one saves them, they should keep opening there.
Member Sumedha
Thats true. But while developing VIs I save them a lot of times. It would be nice if you could make code changes and save a VI x number of times without having to make sure that the VI is located at the correct screen location every time.
It could just be me but while coding especially using two screens I end up messing up the front panel and block diagram location a lot of times Smiley Happy
Knight of NI
This idea seems to be somewhat related to this idea.  We need to uncouple the "edit mode" FP size from the "run mode" FP size
Example Gatekeeper
Example Gatekeeper
Status changed to: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
