Right now the only way possible to set the tabbing order of controls on the front panel of a (sub)VI is to use Edit >> Set Tabbing Order.
I would like a VI Server property/method to be able to programmatically set the tabbing order of the controls on the front panel the way I want. This way I can write a script to fix a large number of VIs without needing to manually click through each one. (Of course I would be responsible for programmatically figuring out the order I wanted, but I could make some general assumptions like following the top-bottom left-right on the front panel existing layout, or following how they are connected to the connector pane, etc)
