If an image has calibration information, then there should be the option to either display the scale in pixels or in calibration units. Setting an offset would be useful in that case.
Can you elaborate on why you need the multiplier property as well?
"If an image has calibration information, then there should be the option to either display the scale in pixels or in calibration units."
Agreed. Then you would not need the multiplier property node because what you say above is equivalent.
I mentioned the multiplier property node because I used that for intensity graphs. The intensity graph was my preferred alternate image container to Vision image containers in many cases becauses of the fact that scales were not available on the Vision image containers.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
