Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
Similar to specifying the Access Scope for multiple VIs in a library by grouping
them in a Virtual Folder and setting the Access Scope of the folder, I'd like to
specify locking or password protection for multiple VIs in a LabVIEW library by
enabling that on the owning Virtual Folder. The dialog would be the same as if
you were setting the Protection on the entire library from the Properties menu.
Do you mind if I ask a moderator to change "protection" to "locking/password" in your idea title and text? Since "Protected" is one of the access scopes, I was really confused by your description.
