Ctrl-X, Ctrl-C, and Ctrl-V shortcuts for cut/copy/paste do work in the Quick Drop text box as long as there are not custom keyboard shortcuts associated with those keys.
In some cases, it would be very useful to be able to copy and paste the text of the selection box.
If you don't have custom shortcuts assigned to Ctrl-X, Ctrl-C, and Ctrl-V, then they will perform cut/copy/paste actions within the Quick Drop text box. So this functionality is already available. Am I misunderstanding your idea request?
The default shortcut is actually derived from the VI Description of the plugin VI. It is the key inside of the brackets. Or you can just simply change from the default using that configuration window.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Instead of typing only the key, I tried to change the shortcut by typing the whole key combination. Therefore the Set button of the QD Configuration window remained greyed out.
Many thanks for helping me to become a little less stupid !
