Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Add Connect as an option when right clicking on an empty Connector Pane Terminal. In addition to single clicking, since you can right click and disconnect it would be nice to also be able to right click and Connect a Terminal
I first thought; "Why, this is the primary action you do on the conpane with left-click?". But JasonAE suggests that you mean so you can select from a list what to connect to, instead of hunting around on the FP - is that it?
