About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Add Conditional Disable Symbols tab to the Build Specification
I have a project which compiles to 2 different executable for different hardware targets.  I have created 2 Build Specifications which specify different locations for the build output.  However, between compiling each one, I must go to the target options, and change a Conditional Disable Symbol definition so that the other .exe is generated.  If the Build Specifications definition had a tab to specify the value of Conditional Disable Symbols, and which would take precedence over definitions in the project or the target options, then I could build my 2 executables without changing the target properties.
2 Comments
Knight of NI Knight of NI
Knight of NI
Example Gatekeeper
Example Gatekeeper
