Ability to export graph properties along with graph data from subvi without resorting to "references" to access changed properties of graphs in a subVI
I hope I am interpreting your request correctly.It sounds like you have a graph on the panel of a subVI.You want to be able to have another VI get properties from the subVI without any sort of refnum.
If that is correct, then the following comments apply. If that is incorrect, please post further details about your idea.
In LabVIEW today, you can call the subVI and have it return, by value, any properties of the graph you need. If you want another VI to know when one of the properties changes without calling the subVI, the other VI can either poll for the changes or can have some sort of event listener for the changes. Both of these solutions require a reference or shared data of some sort. Either the caller VI has a refnum that it can poll/listen itself, or there's a global variable or similar shared data that is updated by the subVI every time the graph changes its properties. As far as I know, there's no other solution possible -- any new feature we would add to LV would still be one of these.
If you have a particular idea of what mechanism you'd like to see for doing this, please post it here.
I think (hope) that the OP is referring to the difficulty in getting two graphs (or any objects) to "match" in appearance. Right now you have to wire up Avagadro's number of individual properties, scale, colors, cursors, point styles, etc. Hard to imagine any scenario with a refnum. Perhaps the OP wants a simple way to get two objects to have the same properties.
The problem I see with this is where the line is drawn, I doubt you want them in the same position for example. My own feeling is that it would be nice if there were more bundling of the properties so you have more options to pass grouped properties, while maintaining control over which groups you copy. Perhaps we could do with a few clusters what now takes a couple of dozen individual properties.
I take it you mean dynamically match... statically match is possible just by creating a strict typedef, and both graphs will update as you change the properties.
What kinds of properties are regularly changed dynamically as the VI runs that you would want to keep in sync?
jaffar: I think that makes it clear what you're doing now. Thanks. How would you prefer that it work? I can't think of any solution that wouldn't involve a reference. Do you have a particular mechanism in mind?
