Rather than a surface plot, it would be really nice to have a 3D scatter plot.
Right now, you have to pass a 1D x-array, 1D y-array, then a 2D z-matrix.
This is very non-intuitive, and takes quite a bit of poking around to figure out why this is the case.
It would make much more sense to be able to pass in a cluster of 3 1D arrays of equal length, the same way you do with an XY graph.
In this case, it would be an XYZ graph.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
