User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Currently the 'array build' gives you only the option to merge by rows. If you want to merge by column you first need to transpose the two (or more) input arrays then merge them and then transpose the array again. See VI example attachted. I think this should be changed because it gives a overhead on transpose VI's on your diagram. Therefore I suggest that the 'array build' block gets a option where you can select to merge on columns or rows when a 2D array is used as input.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
