LabVIEW FPGA Idea Exchange
CrisSTine01
erreur lors de la compilation de l'FPGA
Status: New
bonjour,
Voici l'erreur que j'obtiens quand je veux compiler mon programme FPGA
LabVIEW FPGA: La compilation a échoué à cause d'une erreur Xilinx.
Details:
ERROR:Pack:2310 - Too many comps of type "SLICE" found to fit this device.
Design Summary:
Number of errors: 1
Number of warnings: 89
Logic Utilization:
Number of Slice Flip Flops: 7,963 out of 10,240 77%
Number of 4 input LUTs: 10,607 out of 10,240 103% (OVERMAPPED)
Logic Distribution:
Number of occupied Slices: 5,523 out of 5,120 107% (OVERMAPPED)
Number of Slices containing only related logic: 4,143 out of 5,523 75%
Number of Slices containing unrelated logic: 1,380 out of 5,523 24%
*See NOTES below for an explanation of the effects of unrelated logic.
Total Number of 4 input LUTs: 11,028 out of 10,240 107% (OVERMAPPED)
Number used as logic: 10,454
Number used as a route-thru: 421
Number used as 16x1 RAMs: 70
Number used as Shift registers: 83
Number of bonded IOBs: 90 out of 324 27%
IOB Flip Flops: 97
Number of MULT18X18s: 38 out of 40 95%
Number of BUFGMUXs: 2 out of 16 12%
Peak Memory Usage: 359 MB
Total REAL time to MAP completion: 19 secs
Total CPU time to MAP completion: 19
voici une capture ecran du programme
merci d'avance 🙂
1 Comment
RavensFan
Knight of NI
Wrong forum.  This is for new ideas for LabVIEW FPGA.
You need to post in the French LabVIEW forum.  Discussions au sujet de NI LabVIEW
