Hi there,
I got following feedback from a LV FPGA user:
When developing a FPGA application in LabVIEW, after submiting a FPGA code compilation - usually quite a lengthy process - if you modify the code either on the Front Panel or Block Diagram while compiling is in progress, this results in a Compilation Error at the end.
And this occurs regardless the modification be only a mere cosmetic change, without any implication in the code that is being compiled.
This is quite frustrating when you realize that the compilation has failed (maybe after half an hour waiting) just because you unconsciously clicked and resized some control or node.
In such a situation, when LabVIEW detects a code change while the FPGA compilation is running, it should warn the user with a message box; if the user confirms the code change, the current compilation can be inmediately aborted or let it continue (at user option); on the other hand, if the user cancels the modification, nothing happens and the compilation continues to a successful (hopefully) end.
Álvaro
