LabVIEW FPGA Idea Exchange
Manzolli
Remove Stacked Sequence Structure from the FPGA palette
Status: New
Why the "Stacked Sequence Structure" is still present in the FPGA palette? It has been removed from other targets palettes. I think it's better not be in the FPGA palette also.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
3 Comments
Dmitry
Any specific reason you think using it on FPGA Targets is bad ?
I sometimes use it on FPGA (but mostly on host side) to reuse BD real estate during initialization - like setting FP controls/indicators and internal data to a known state. Also ensures everything in the frame executes before proceeding to next frame.
What I really don't like about it are Sequence Locals - clumsy and quite useless in my opinion. I would much prefer having support for Shift Registers to allow multiple frames access and update data in a large cluster ...
Manzolli
Well, it has been banned from Windows and RT. Why keep in FPGA since the only difference is how you (don't) see the code?
André Manzolli
Mechanical Engineer
LabVIEW Champion
