LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
NI Cloud Compile Farm: take advantage of cached cores
When you compile on your own machine, the output of the "coregen" step is cached and used on subsequent compiles.  This saves considerable time.  The fact that this does not happen on the NI cloud service erases any speed gains (and more).
You could:
 - Cache cores at NI.  Save for xx days since last use (or forever if space is not an issue)
 - Transfer cores when they exist (cached locally) to compile server along with other intermediate files
3 Comments
RSteinbrück
N/A
Hi kdnelson,
This thread is somewhat old, but maybe I'm lucky and you're still around.
I set up a Compile Farm Server and an according Linux Compile Worker in our intranet. This Worker has of course a core cache folder. Now I'd like to fill this core cache in advance because otherwise the first compile of a new project takes forever due to the "coregen". Where do I find the cores? Are they installed with LabVIEW FPGA on the Develpment system? Can they simply be transfered to the Linux Worker?
Regards
Reinhard
kdnelson
N/A
I don't think cached cores can help you on the first compile.  In my experience the cores are created by the compiler and cached, I suppose, because they are identified as self-contained units that probably won't need re-compiling next time around.  So caching them helps only on subsequent compiles.  I don't know if there's a way to provide a bunch of pre-compiled cores for common functions--my feeling is that the cores are still pretty project-specific.  But if there were a way, that would be a great addition to this idea: prepopulate the cache as well as retain any other cores generated by a compile.
Nan.Yang
N/A
Hi kdnelson,
There is performance improvement in the FPGA Compile Cloud after NIWeek 2016. Check out the latest compile cloud!
