Memory initialization is one of the more tedious aspects of LVFPGA coding. A lot of my LVFPGA vis have multiple memory elements that I need to access simultaneously for a given operation. I've tried to streamline the initialization process by making all memory initialization vis read from an init values file and populate the array indicator. However now I have to have multiple initialization vis reading from different points in the same init values file. If I could somehow get a parameter into the memory initialization vi, I could programmatically select from where in the init values file to read. Here is how this could work:
