Make It Easier to Determine Current Xilinx Compile Tools Version, and Distinguish Between Xilinx 12.4 and Xilinx 12.4 SP1
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Presently, the Xilinx Compile Tools do not appear in the MAX technical report or NI License Manager. As a result, to determine the version, users must go to Add/Remove Programs in the control panel to determine which versions they have installed. It would be great for troubleshooting if the Xilinx Version could be implemented into the MAX technical report.
In addition, the Compile Worker states that the version of Xilinx used is 12.4, regardless of whether you are using 12.4 or 12.4 SP1. It would be useful for the compile worker to note which version it is using. Specifically, often the compilation chooses the compile tools based on what it was compiled with previously. When upgrading to 12.4 SP1, the user may think the compiler automatically uses the new compile tools and has no visual cue to verify the compile tools version used.
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
Watch as the community gives your idea kudos and adds their input.
As NI R&D considers the idea, they will change the idea status.
Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
