NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Manzolli
Index to NI 9802 port access
Status: New
by Active Participant Manzolli on ‎03-30-2010 08:47 AM
The NI 9802 (Secure Digital Removable Storage Module for CompactRIO) is a cRIO module that has two SD memory card slots. The problem is that the programmer cannot index the ports as "0" and "1". The solution is to write a code for "0" and repeat it for "1".
The proposal is to allow the user to select memory card by a terminal in the "Method" and "Property" nodes.
Since the maximum amount of memory per card is 2 GB, if more than 2 GB is needed, the programmer should manage to split the data in two cards. Right now the code should be duplicated and selected by a "Case" structure. In many other situations the programmer may need to use one or other card, like when a big file should be saved after the usual check of the available free space in both cards.
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Idea Statuses
Top Kudoed Authors
User Kudos Count
8
5
3
2
1
