LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Top Kudoed Authors
Incremental Compile LabVIEW FPGA
Hello all.
It is time-consuming that we have to compile all LabVIEW FPGA code even if there is tiny little change on FPGA code.
I understand there is sampling probe, Desktop execution node and simulation tools to reduce such time.
Our customer in Japan, would like to use incremental compile function also on LabVIEW.(Please see below)
I agree his opinion.
http://www.youtube.com/watch?v=9v50uCVdW3o
What do you think?
Eisuke Ono
Application Engineer at National Instruments Japan.
5 Comments
I think this is something everyone would like to see, I'm glad someone finally posted an idea for it to get feedback from the community. With the introduction of (better) incremental compilation in the latest 3rd party tools like Xilinx there is certainly some features the LabVIEW FPGA compiler could take advantage of. There is also plenty of optimizations within the LabVIEW FPGA compiler itself that could help.
The problem with incremental compilation of any kind is doing it well enough that the majority of use cases don't suffer performance issues when squeezing application changes into as few changes in the actual hardware. Getting this balance right takes a lot of work and a lot of sample applications to try it against.
Just to clarify, my vote for this one comes with serious respect to the manifold technical challenges that will likely be encountered, as alluded to by Dragis.
Nonetheless, I think it would be fantastic if it could be implemented well.
Trusted Enthusiast
As long as we can still opt to do a full compilation im in.
The importance of this one is only going to increase as the growth in FPGA complexity continues to outpace the single threaded CPU performance required to synthesize designs.
I wish it was already implemented.
When changing even a COntrol name, I have to compile again, and it takes nearly 5 hours... It makes it so hard work with it when you need to code and fix when validating the system with  the customer.
Short story, I'm also working on a project and we use VHDL IP, so the VHDL guy asks me: Why would you compile everything? it will take forever... I explain him the issue, and he told me that it should be easy to compile only the modified functions (i.e modifying a sub vi should compile only the shub VI and a small portion of the calling VI)
Rodéric_L
Certified LabVIEW Architect
