LabVIEW FPGA Idea Exchange
gsussman
Improved Search Scope for IO and Memory X-Nodes
Status: New
When you configure Memory in LV FPGA, there is no way to find specific references to particular memory blocks using the search function. The search will show "ALL" memory access nodes, not just the ones you are looking for. Additionally a text serach will not catch the text from the X Nodes. This can be particularly tedious if you have many nodes in your hierarchy and are looking to only see references to a particular memory block.
I would like to see the search improved to allow filtering of the memory nodes the same way that we can search for global variables (find definition and find references)
1 Comment
Terry_ALE
I agree with this request.  Current work around is to put each of these functions in a sub-VI which then make them searchable.
ALE Consultants
