LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Import export IO user label to and from excel in FPGA project
Hi How about facility of import and export of I/O Label in FPGA-Real time project as shown image instead of manually renaming each I/O
3 Comments
crossrulz
N/A
I would suggest using a tab delimited text file.  That way we don't have to have Excel.  But this would save me a lot of time.
PBP
N/A
CSV or  tab delimited text file will work.
Sam_Sharp
N/A
I have +1'ed this idea as it's something that's really useful when you work in a design team and your electrical engineer asks for a pinout of the CompactRIO. I think it would be useful if it would also include module/slot location information as well.
I have attempted something like this before and found that it is possible to do something similar by a couple of methods:
1) Use an .xsl stylesheet to generate html from the LabVIEW project that filters based on the target information. You can do this programmatically using an XSL transformation. This is the result I got (not very aesthetic but I didn't take it very far):
2) Export the information from the Project using property nodes (Project.Targets)
So while I think it's great to have this built into the IDE, there are a couple of ways to do it at the moment.
