I find that I'm using large bit FXD to handle the dynamic range, but I only have 8 or 16 bit significant bits. I have an I2S input of 24bit numbers that I store in memory as U16 with the following incoding Number = A*2^(B), where A is a FXD(+/-11,9) and B is a FXD(+/-5,5). A and B are bit spliced array that form the U16. This allows me a 33% memory reduction covering a greater dynamic range by trading off resolution. Here the I2S input allows the counting of leading zeros or ones to create the number B and conversion back to 24bits is easy. Three items would make this a great help: 1. a typedef, 2. a quick forward convertor from standard form to FP FXD, and 3. gain inputs on math elements such as FFT if they canhandle FP values.
