In a FPGA code, when you click in a function (Math, Array or Comparison) to create the first constant, control or indicator, like in an Add function, it's created as a Double (DBL) type, which is not suitable for this target. In this case, it will be better if the data are created as a Fixed Point (FXP). In other cases, like in Array functions, an Integer (I32) may be a better option. One thing is for sure: Should not be a Double!
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
