LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Bring FPGA over to 64 bit LabVIEW
Vision is available under LabVIEW 64 bit and this makes sense since vision can generate very large amounts of data.  I think now is the time to bring FPGA over to LabVIEW 64 bit as well.  With FPGA systems you can also generate very large data sets.  Also with cards like the PCIE 1473R, you have a VISION requiring card that generates lots of data, but it requires FPGA, so you can only use it in LabVIEW 32 bit.  This is not a good thing.  It has been 5 years since LabVIEW 64 bit has been released  it is time to finish moving the addons over to 64 bit.
5 Comments
Manzolli
N/A
Since the end of 2012 I'm only buying PC with 8 GB of RAM or more with a 64 bit OS. It's time to LV 64 take the lead! Kudos!
crossrulz
N/A
The compiler might be stuck in 32-bit.  But that's a Xilinx issue.  That could be what is holding this effort up.
Kirk
N/A
Even if the compiler is stuck at 32 bit, that should not hold up LabVIEW FPGA working in 64 bit.  The compiler is a seperate program and can run under 32 bit, but LabVIEW should be able to run at 64 bit and download the FPGA code and run it under 64 bit.
crossrulz
N/A
Oh, I fully agree.  I'm just trying to understand NI's side.
Dragis
N/A
Putting on my NI hat, this is certainly something NI is aware of and has been investigating for some time. Like others mentioned, LabVIEW relies on many third-party components which themselves may not have 64-bit couterparts, etc. Moving to 64-bit is a large endeavor, but it will happen eventually. When is eventually, well that's another story : )
