We can programmatically mass compile VI's and build executables but there is no easy method to compiling FPGA code. We have a large application that consists of C++ and LabVIEW code. We have automated our build process but we still have to compile the FPGA code using a procedure. It would be nice to write a script or a VI that would compile all of our FGPA code.
There should be a way to interactively perform a "build all" so that I can take my multi-target project and start a compile overnight to rebuild all targets.
I attach a VI which I originally found on the forums which has saved me so much time!
It allows for the mass compilation of FPGA bitfiles for different targets.
I have slightly improved the original version by cleaning up the front panel, error wiring, and reference closing which massively cut down on RAM usage and # of windows open.
I hope that it saves you as much time as it has saved me. I wish I could give credit to the original author.
