LabVIEW FPGA Idea Exchange
J_Bangasser
Be able to programmatically compile FPGA code
Status: New
We can programmatically mass compile VI's and build executables but there is no easy method to compiling FPGA code.  We have a large application that consists of C++ and LabVIEW code.  We have automated our build process but we still have to compile the FPGA code using a procedure.  It would be nice to write a script or a VI that would compile all of our FGPA code.
6 Comments
srm@viewpointusa.com
I agree.
There should be a way to interactively perform a "build all" so that I can take my multi-target project and start a compile overnight to rebuild all targets.
Stu
pnouvel
I agree
In addition, It would be very usefull to have a documented access to the CDR of the VI that are used to launch the compilation :
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\rvi\CDR
Cordialement / Regards
Patrice NOUVEL
Project Leader
CLD
nkraemer
I agree. It would also be nice to be able to launch post-build scripts or VIs as well
Gryffin
I attach a VI which I originally found on the forums which has saved me so much time!
It allows for the mass compilation of FPGA bitfiles for different targets.
I have slightly improved the original version by cleaning up the front panel, error wiring, and reference closing which massively cut down on RAM usage and # of windows open.
I hope that it saves you as much time as it has saved me. I wish I could give credit to the original author.
https://forums.ni.com/ni/attachments/ni/170/1234463/1/BuildFPGAs.vi
J_Bangasser
Any chance you can compile your BuildFPGA.vi in an order version of LabVIEW?  I am using LabVIEW 2020.
Thanks!
Gryffin
