I find Conditional Disable Symbols in FPGA code very useful especially in a R&D environment where needs and code change back and forth rapidly. However, I also find it hard to keep track of all these changes. I propose to add support for reading FPGA Conditional Disable Symbols from Host to enable VIs like "Is_FPGA_Function_A_Enabled.vi" that would allow for the Host program to know the state (hardware revision of sorts) of the FPGA bitfile and adapt.
I'll give an example to illustrate this proposal.
Function A is implemented in FPGA bitfile v1. Function B is implemented in Host and is based on multiple calls to Function A. Your boss now wants Function B implemented in FPGA for performance reasons with means to disable the code if required. For this you define a Conditional Disable Symbol in the FPGA project "FPGA_WITH_FUNC_B" and write FPGA code for FPGA bitfile v2. Switching between v1 and v2 is easy enough from the project manager, but for the Host side there's no way of knowing whether Function B is implemented directly in the FPGA or should be "emulated" via Function A as before. If you could do a check like "if FPGA_WITH_FUNC_B == TRUE" you could easily make the Host aware of this.
solarsd
