LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Top Kudoed Authors
User Kudos Count
1
1
64 bit FPGA tick-counter
The Tick Count function in LabVIEW FPGA can represent time periods with tick count accuracy of up to 2^32 clock cycles, that is (using the standard 40 MHz FPGA clock) about 107 seconds.
Sometimes I need to handle longer time spans, and I use this example.
I suggest to implement a built-in 64-bit tick counter.
3 Comments
muks
N/A
A direct 64-bit clock will be very much needed. Kudos!!
Dragis
N/A
i like the idea, but i think we should take it a step further and allow the user to wire a constant 'max count' into the node. the internal counter can then be optimized to use the fewest bits necessary to meet that criteria.
igagne
N/A
This is useful regular labview too. A 50 day overflow is too short.
