Hi there,
I have an sbRIO project, in which I'll have to update the Realtime and the FPGA program. The variable engine is defined to be run on the sbRIO.
I found that just using the FTP to overwrite the original RT startup programm doesn't make the new settings of the shared variables work. I've also try to use the deploy variables using the Windows EXE application. But still I cannot find the new variable in the variable engine.
The question is how to update the variable engine without the full installation of LabVIEW, and also without the auto-deploy option of the windows program. Maybe also gut to know, how to reset the variable engine on the sbRIO target, without using the LabVIEW project window?
