I have a Keil MCB2300 setup and successfully running w/ LV2010. I want to know how do I change the digital pins from outputs to inputs. LabVIEW defaults to 7 outputs and 1 input, but surely I can chan;ge these. The Keil schematics just label the pins as digital w/out designating input or output.
I found a document that I think may be helpful in configuring your inputs/outputs. It details how to create new I/O items for ARM targets which is what I believe the Keil MCB2300 is. Try following the steps in this document.
I should clarify. In the 2nd image above pins 2.0 through 2.7 are already available in the LabVIEW Project manager under "Available Resource." However, I want to access the other digital pins (pins 3.0 through 3.7) How can I add these pins to the list of available resources in LabVIEW?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
