NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
David-n-MO
breakpoints don't work and probes don't update...
I've got labview 2009, corrosponding ARM module and a Luminary LM3s8962.
Because of the size of my project I had to disable debugging to make it fit.  But now that I want to start debugging, (removed a loop to make it fit) I can't get breakpoints to  break and the probes don't update.  I did check the debug box in the build, but it still doesn't work...
Any ideas anyone???
David
Member
NicB
Re: breakpoints don't work and probes don't update...
Disable/Enable debugging works well for me.
I would suggest a Rebuild All (Generate C Code... window should appear), but before doing this remember that "Enable Debugging" in "Application Information" panel don't overwrite settings from "Source File Settings".
How is the running arrow of the top level VI?
Member Gmg
Member
Gmg
Is this JTAG or serial/TCP debugging?  If you are using JTAG, see if serial/TCP debugging is fine (although this will increase your program size further).
Member
David-n-MO
Aaah, time moves on and the past continues to repeat itself...
But this time I'm using labview 2011 real-time and on cRIO and PXI chases.
I'm experiencing the same problems I had before in that even though debugging is enabled.  I try to debug using execution highlighting and breakpoints and they don't do jack.  this is especially true if timed loops are involved.  Now the processor is not anywhere near maxed out.  I have pretty much given up trying to use these tools when this happens, but today a co-worker experienced the same problem and asked me what is going on.
So, Someone tell me what is going on!
Member
mumansky
I've found that using the CCG Console Output VI works fairly well for small string outputs. It'll push the string to the build report/output window.
Member
David-n-MO
Yes, that is one way,  and it is also a great way to log initialization progress without resorting to writing a log file.  But while there are work arounds I would still like to understand  why the tools don't work as advertised.
Thanks for the reply.
Member
Kevin_H.
You'll probably have better luck giving a complete description of the problem over at the RT Forums. Providing explicit steps for recreating what you're seeing will allow helpful people to figure out what's going on a bit faster!
Kevin
Member
David-n-MO
Just my luck...  I go to the doctor and find out I need a specialist.  Thanks for the referral!
David
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
