NI Home
Cart Cart | Help
You are here:
Reply
Member
Peter_B
Re: Survey: LabVIEW Embedded experiences
Hi Wouter
Thanks for trying things out.  It appears to me that what you claim in theory is not possible in practice.  Is that right ?
You claim that "if you want to speed up your parallel code (using disable parallel execution),you want to use timed loops", however neither of us are able to implement this in even a simple example.
If this is the case then LVEA still has a huge problem because putting down parallel loops of any kind severely degrade performance/speed compared to the same code in a single loop.  This is a real shame as the beauty of programming in LabVIEW is the ease of which parallel tasks can be coded.
Peter Badcock
Product Development
ResMed Ltd.
Member
Peter_B
>> 5) It would be great to see what performance degradation you get on your faster boards between code in on loop with all the fastest compiler options and then the same code split into two
>> loops with the fastest compiler changes to make it run in parallel. You'll either get only a halving in speed (great!) or a five time reduction (bad news for me).
> I will have to do this :smileytongue:
Hi Wouter,
You wrote that you were going to try out this experiment and see if you get much worse perfomance as Vito and I do when splitting one while loop into two parallel while loops.
Have you done this yet ?
Peter Badcock
Product Development
ResMed Ltd.
Member
w0utje
[ Edited ]
Disable parallel loops gives smaller code. (no need for LV scheduling)
and at that point if you want to use paralelism, you must use timed loops. (like two main tasks)
I don't know what's the cause of the not working code if you use timed loops and all the optimatization.
So, we concluding that for loops are faster then timed loops. I will have to play with timed loops to set the period smaller. (I've set this to 0 ms), but I don't know which period is used. (delay?)
If you disable parallel execution with for loops, only 1 for loop will run at the time. If you replace the 2 for loops with infinite while loops, it will only run one while loop..
I've tested one application on the LPC1788, I have the following timings:
lm3s8962: 90.798 ms and 182.647 ms
lpc1788: 68.788 ms and 140.751 ms
so the lpc1788 is (90.798 / 68.788) = 1.319 and (182.647 / 140.751) = 1.297 times as fast (let's say 1.30)
let in mind that this is the test with the timed loops.
Wouter
Wouter.
"LabVIEW for ARM guru and bug destroyer"
Active Participant
vitoi
Thanks Wouter,
It's surprising and disappointing that the LPC1788 didn't perform better. The LPC1788 has twice the CPU clock speed (and therefore MIPS) than the LM3S8962, however it only performed ~1.3x better. And presumably with compiler options that only get ~20% of the CPU performance.
Would it be possible to incude the VIs you used and the compiler settings?
Rgards,
Vito
Member
w0utje
I will have to test the lpc1788 with the other tests also (not timed loop)
I have experienced 75% better performance with other apps.
here are the test vi's (LV 2010) in 7zip.
Wouter.
Active Participant
vitoi
Hi Wouter,
Thanks for your VI. I will try it tomorrow when I'm back at work.
Any chance of you running the following two VIs with the compiler options as shown on the LPC1788 board.
They are provided as snippets so hopefully you can just drop them into a blank VI. You will need to replace the display routines with whatever display you hve on the LPC1788.
The times for these runs will tell me everything I need to know about LabVIEW Embedded.
Member
w0utje
I can't use them because they are for LV 2011.
If you save them for LV 2010 I can use them.
Wouter.
Active Participant
vitoi
Hi Wouter,
Please find attached the zipped Timing Evaluation project.
If you get time to time the two VIs it would be great. When doing the timing, don't take the first run. Instead reset the board and take the next run (all other runs are exactly the same timing, at least for me).
Thanks and Regards,
Vito
Member
w0utje
Thanks, I am going to test it.
So you are using LV for ARM 2011?
with standard LM3S8962 target?
I see for the LM3S8962 in LV 2010. that the timings are:
test 1: 113 ms   (LV 2011 134 ms)
test 2: 640 ms and 682 ms (LV 2011 718 ms)
Wouter.
Member
w0utje
first test results,
LPC1788
test 1: 97.975 ms
test 2: 779.247 ms and 921.668 ms  ( Why so long!?)
Wouter.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
