01-31-2013 12:03 PM
Hopefully this is the correct forum. Please correct me if it isn't.
Does anyone know of a good tutorial on getting LabVIEW CCodeGen working with a Keil Project using RTX? I am using LabVIEW 2012 with the 2012 CCodeGen evaluation installed. I have gotten the basic example using a keil project working and I have done a non-RTX Keil project that seems to work just fine.
However when attempting to port this to a project with RTX OS I am having little luck. The LVRuntime code seems to recognize that RTX is in use but I seem to be missing some includes or something.
Thanks for any info to point me in the right direction.
02-01-2013 09:49 AM
Answered my own questions via the "Getting Started with the NI LabVIEW C Generator" document. On page 15 "On the Target tab, notice that Operating System is set to Nothing. Do not set this value to RTX, which is incompatible with the generated C Code."
That would explain all the __RTX related errors I get when trying to build.
