NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
MarM
LV Embedded + ARM7
is it possible to use LV Embedded module on ARM7 processor??? Is the requirement of 256Kb RAM critical???
Marcin
Member
pjtanz
Re: LV Embedded + ARM7
Hello Marcin,
Yes, we have seen LabVIEW running on an ARM7 running eCos as an operating system.  There's no reason that it shouldn't be able to run in other configurations as well.   As is the case with any LabVIEW Embedded Development Module target, however, this will require some up front integration work by you in order add support for the target to LabVIEW.
It's not critical that there be 256K of RAM for the applications to execute, however, you will need at least 256K of program space  (this can be RAM or FLASH ) in addition ot  whatever is necessary for your OS or support libraries to have enough room to develop a reasonable LabVIEW Embedded application.
For more information on what is necessary to bring up a target, you can check out the training class for LabVIEW Embedded here.
I hope that this helps.
P.J.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
