NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Ahmed.Abdulbaky
How can I use the Variable Delay VI (From DSP Module) to Deploy Variable Delay on Speddy-33
Dears,
I dont Understand How Can I Use the Variable Delay to Deploy Variable Delay on a Speedy-33 Kit
Member
Margaret F.
Re: How can I use the Variable Delay VI (From DSP Module) to Deploy Variable Delay on Speddy-33
Thank you for posting to the NI Forums!! You should be able to incorporate the Variable Delay.vi into your vi and then build as normal and the functionality of the vi should translate to the build. What type of build are you doing? Are you receiving any specific errors? Thanks!
Margaret Barrett
Digital Multimeters and LCR Meters
Member
mr Joe
can i have the variable delay.vi plz..thanks
Member
Brian_A
Hi mr Joe
The Variable delay.vi is a node in the DSP Module. You will need to purchase the DSP Module to use it.
Here is a link to where to purchase the DSP Module if you would like the Variable delay.vi
LabVIEW DSP Module
<Brian Aswege | Applications Engineering | National Instruments>
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
