06-21-2011 10:10 PM
Hello there, I am currently turning to make a project run on a STM32f103C8 chip using LabView with ARM. I am currently trying to compile a ARM project but I have no been successful.
I have tried using the STM32F10x template uploaded by Joshua, and it tries to compile. At first I was getting the "stm32f10x_tim1.c" file missing error, but that was solved by downloading the file from firmware v1 and adding it to the includes folder. but now i am getting a new error saying "profile_timer.h" is missing.
I am using:
Windows 7
LabView 2010 evaluation
NI ARM module
and I am trying to compile a empty project
Here is the error code message, any hepl will be useful, thanks:
[12:39:37 PM] Status: Error
Build target 'LabVIEW'
compiling RTX_Config.c...
F:\National Instruments\LabVIEW 2010\CCodeGen\include\os\rtx\LVDefs_plat.h(17): error: #5: cannot open source input file "profile_timer.h": No such file or directory
compiling Retarget.c...
compiling TargetInit.c...
compiling ARM_Serial.c...
compiling LVTree.c...
compiling Pict.c...
compiling arrresize.c...
F:\National Instruments\LabVIEW 2010\CCodeGen\analysis\development\include\platdefines.h(321): error: #35: #error directive:
Target not created
Status: Build failed.
06-22-2011 03:16 PM
Are you refering to the port that Josh posted here? I found a couple of "profile_timer.h" files on my system associated with other targets.
You could try modifying one of these.
Also have you tried compiling a project with one of the supplied targets? Do these work for you or do they give you an error as well?
06-22-2011 08:18 PM
yes, sorry, i meant to paste the link, i even had the post highlighted
I'll give that a go right now
06-22-2011 08:53 PM
blank projects using other included boards seem to compile fine
and i have added a mock "profile_timer" to the keil library (just as a quick fix) and it seems to have stopped a lot of the errors, however i am still getting a few
these seem to be:
compiling CCGDatalogSupport.c...
F:\National Instruments\LabVIEW 2010\CCodeGen\libsrc\comms\CCGDatalogSupport.c(23): error: #5: cannot open source input file "CCGFileSupportPriv.h": No such file or directory
compiling CCGFileSupport.c...
F:\National Instruments\LabVIEW 2010\CCodeGen\libsrc\comms\CCGFileSupport.c(22): error: #5: cannot open source input file "CCGFileSupportPriv.h": No such file or directory
compiling CCGFileSupport2.c...
F:\National Instruments\LabVIEW 2010\CCodeGen\libsrc\comms\CCGFileSupport2.c(22): error: #5: cannot open source input file "CCGFileSupportPriv.h": No such file or directory
compiling CCGIrDASupport.c...
compiling CCGNetConnRefNum.c...
compiling CCGSerial.c...
compiling Pict.c...
Target not created
i'll see if i can find a file for the ccgfilesupportpriv.h but the error directive worries me a bit
06-29-2011 10:12 PM - edited 06-29-2011 10:15 PM
I just ran into the same issue.
When looking inside CCGDatalogSupport.c for instance, it appears that it will only include if the __RTX symbol is undefined.
#ifndef __RTX
#include "CCGFileSupportPriv.h"
#endif
It turns out that when I opened the Template\Project\LabVIEW.uvproj in Keil uVision4 to change the target type, it decided to change mOS to 0. I simply changed it back to 1 with a text editor and everything builds just fine now.
<mOS>1</mOS>
Hope that helps,
-Joe
08-30-2011 03:42 AM
I just recently installed Labview embedded 2011 and tried to run the Blinky example for my LM328962 board - When compiling I get also th message :
..\Include\profile_timer.h(4): error: #5: cannot open source input file "hw_memmap.h": No such file or directory
I searched through the whole filesystems (Labview embedded 2010 was never installed !) and could't find any profile_timer.h file.
What to do ?
08-30-2011 04:02 AM - edited 08-30-2011 04:04 AM
O.K. - the problem could be solved by adding the include path : C:\Keil\ARM\RV31\LIB\Luminary
Anyway this failure message remains :
[10:58:29] Status: Error
C:\Keil\ARM\RV31\INC\RTX_lib.c(183): error: #29: expected an expression
compiling File_Config.c...
What to do ?
09-04-2011 05:59 AM
any news - quite poor that basic examples don't work ...
09-04-2011 05:43 PM
i know..... I've kind of gotten off on using Labview
01-26-2012 02:57 AM
you can comment out the define in RTX_Config.c
row 102 :
#define __RTA_RTX_CONFIG
I never use the Real Time Agent (RTA)
It's if you want to "see" indicators live when debugging/running your device.
I use the UART if I want to see something (or debug in KEIL uVision)
