LabVIEW Embedded
Can I use ulink1 or ulinkme to replace ulink2 in labview arm ,ulink2 is too expensive.I use mcb2300
Can I use ulink1 or ulinkme to replace ulink2 in labview arm ,ulink2 is too expensive.I use mcb2300.
(5,748 Views)
You'll miss JTAG debugging since Real-Time Agent is not supported.
I think you'll be able to program and use instrumentation debugging (serial, ethernet)
See a comparison of the Keil tools:
http://www.keil.com/ulink/cmp.asp
(5,746 Views)
