09-03-2016 02:23 PM
09-06-2016 08:35 PM
USB 6211 can be used with EPS toolkit. I suggest you using the example VI "Basic Power Measurement.vi" if you need to get frequency and RMS value.
This example measures 3Ux3I values. So please select 3 channels in "voltage channels" and another 3 channels in "current channels". Then adjust the maximum and minimum values for each other. For voltage, the span is +10 to -10. For current, the span is +0.04 to -0.04. Run the example and I believe you can get the appropriate values.
Thanks!
09-06-2016 08:35 PM
Thanks!
