04-09-2014 06:46 AM
Hi :
I am doing some cRIO project, the procedure is like this:
By creating a project communicate with cRIo monitor systems. The code has been created to caculate the data package and send as shared variable.
The shared variable connect with datasocket write (same proejct), I try to directly using the Matrikon OPC . so i write the URL like:
opc://130.88.8.227/Matrikon.OPC.Simulation.1/Bucket Brigade.Real4 , it is said error .
I already try to use simple OPC write and OPC read in the same computer which URL change the IP address to Localhost, it is working, but when i change it to the IP 130.88.8.227. It just not working. The Vi was in the attachment.
Can i ask , is it because of Port configuration or other problems , wait anyone response.
thank you very much
Zhang Min
04-09-2014 06:59 AM
Futher explanation : apart from modules installed based on the cRIO, did i need to install the DSC module as well ?
Kind regard
Zhang MIn
04-10-2014 01:15 AM
Hi Zhang Min,
Please post your question here.
This board is for Electrical Power Suite related questions.
