First question is what you want to measure?
If you want to measure power quality to IEC 61000-4-30 then you should know that the FPGA resampler only operates on 50 or 60Hz networks and this wont work.
It looks like it is the same for the host-based resampler as well (you still must specify a 50 or 60Hz system).
The basic measurements palette thought looks like it maybe a bit more flexible though. For example, the harmonics palette has a resampling VI that takes external trigger times and so doesn't seem to depend on the system frequency so much.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
