I'm looking at the example finder application "Quality Applications.lvproj" for the Electrical Power Suite for labview 2011. I'm trying to read a single cycle voltage reading for 3 phase power using the vector measurement. The example is using a "FPGA Resampling (60 Hz).vi" that appears to resample 12 cycles and send this to the realtime via DMA. I'm willing to trade quality for speed and reduce the number of cycles used to buffer.
When I run the "Magnitude & Frequency.vi" I can change the frequency being displayed on the front panel, but the underlying FPGA code is still putting 12 cycles of data in the DMA.
What is the best approach to read "instantaneous" voltage? Where is the EPM library setting the sampling of the resample block?
