11-23-2014 10:59 PM
I want to measure RMS value of current and voltage signal which I am getting by using CRIO 9076 analog input card. I have used rms block from electrical power of LabVIEW, but value varries from 0 to rms which is not required. So, suggest me program for measuring rms value measurement.
11-28-2014 03:12 AM - edited 11-28-2014 03:13 AM
11-28-2014 04:17 AM
Dear Levis,
I am using NI 9205 card for measuring volatge, current and power. Here I have attached image of my simulation. Please suggest me what is the problem I have made in it?
11-30-2014 08:04 PM - edited 11-30-2014 08:07 PM
Dongre,
Please do take the examples as reference first.
<National Instruments>\LabVIEW 2014\examples\Electrical Power\Power Quality\Applications (cRIO) (SAR) or Applications (cRIO) (Delta-Sigma) - depending on the type of the modules you are using . If you do not want to use FPGA to resample the data but to use cRIO CPU instead (which is not recommended), the Applications (DAQmx) folder is a good reference.
02-12-2016 09:17 AM
Can any one please explain me how to set Sample time in Energy block.
kindly attach .vi file calculating energy from simple simulated sine wave.
It will be great favour
Thakin you in anticipation
02-27-2016 12:09 PM
Please don't spam the forums by resurrecting multiple old threads and asking the same question.
continue with the post here http://forums.ni.com/t5/LabVIEW-Electrical-Power-Suite/Re-Electrical-power-energy-auditing/td-p/3252...
which I put into its own new message thread.
