09-07-2016 10:35 AM
Hello;
I'm developing an application using the Electrical Power Suite. I use a old PC with labVIEW 2014 and EPS 2014 and I develop my application.
Now, I'm using another computer. I have installed labVIEw 2014 and EPS 2014 in this new computer but, when I open the labVIEW project (which I develop in the other computer) I always have a dialog box to find the EP System Info.lvclass and some functionality of my application are not working correctly.
Is there any way to "compile" or to tell labview where to find the file?
10-31-2016 08:05 PM
You could try a Mass Compile.
01-03-2018 10:35 PM
hi,
I am new to electrical power suite. I have to generate events (sag,swell,interruption). This event tool is there in electrical power suite. This event tool contains lot of input.One of the input is system info in and one of the output is system info out.I don't know how to use these input and output.If i want to use system info in one instruction will come " System info in require basic configuration of the system use initialize vi for basic configuration". This initialize vi tool contains voltage,sample per rate,wiring etc..Then how can i combine these event tool and initialize vi tool in electrical power suite.
01-03-2018 10:36 PM
01-03-2018 11:16 PM
Electrical Power Suite is used for detecting the events (dip, swell, interruption) from the input voltage signals, not generating event signals.
You could refer to the examples for how to use the EPS VIs. And you could search the example from Example Finder.
