05-23-2014 07:50 AM
Hello Everyone,
I've Delta DVP 20EXPLC. In this PLC, we can generate the pulsed outputs at Y0 and Y1. I wish to do the single phase inverter with the help of this pulses. Now, I am using four MOSFET which are going to operate the switches for inverting operations. Basic inverting operation is at that time pair of MOSFETs only should be on, remains or OFF. The problem for me is, When I'm giving the pulses from the PLC, the pulses of 4 MOSFETs are same, It cant operate with the above format. So, I didn't get inverted sine wave signal.
I hope that You can understand my status. If it is not sufficient, I am ready to explain deeply according to the reply. Please help me with out this problem.
05-25-2014 12:55 PM
What odes this have to do with LabVIEW? Do you have suitable high side drivers for the MOSFETS?
Lynn
05-25-2014 11:37 PM
Yes I have.
