LabVIEW E.N.A.B.L.E.D Discussions
Reply
installation help
Go to Solution
Highlighted
installation help
I have installed LABView 2013 version.Apart from that i need to use the VISA function for serial communication.What else do i need to install..?
Message 1 of 7 (910 Views)
Reply
Re: installation help
Hi Archit,  Did You Installed Device Drivers with labview 2013?   Regards, Krish.
Venugopal
Message 2 of 7 (365 Views)
@Krish : yes i have installed device drivers... But the problem is when i create a program using visa resource name nothing is indicated ( ie com1/com2) in it..i only see refresh button.
Message 3 of 7 (365 Views)
Reply
‎06-06-2015 01:02 AM
Hi Archit,  There are few things to consider 1. Check your com poprt displayed in Ni max. 2. Check in your control panel>>Programs whether Visa shared components is installed. 3. Version of the Device Drivers Should be same as the labview Version.                 (or) Simply re-installing labview and its Device Drivers May Solve Your Problem. But, Before Doing that Backup Your Work.  Thanks&Regards, Krish.
Venugopal
Message 4 of 7 (365 Views)
Thanks krish..Problem is solved...Appreciate your help..Thanks again..
Message 5 of 7 (365 Views)
Reply
Sir I m a final year b.tech student from electrical and electronics branch. Currently I m working over my b.tech project which is pencil sorting using LabVIEW...can anyone plz help me in interfacing DSLR or other high resolutions camera using LabVIEW ....help me plzz
Message 6 of 7 (183 Views)
Reply
Hi mkswain421,
                    You can go with Basler ace GigE Camera. It may comes with better resolution for your requirements.
Message 7 of 7 (74 Views)
Reply
