LabVIEW E.N.A.B.L.E.D Discussions
Reply
can we interface xbee modules to labVIEW
Go to Solution
Highlighted
Can i know the procedure ?
Message 1 of 8 (2,005 Views)
Reply
Re: can we interface xbee modules to labVIEW
Dear Nihanth,
It depends on which type of approach you are going, as far as i`ve worked on transmitting and receiving the signals through Aurdino and Microconroller with xbee.
Ganesha Moorthy
Message 2 of 8 (335 Views)
Reply
Hello Nihanth,
first of all, can you provide the details of your interface ,like Serial or any other.
if serial is your answer, then it is very easy to communicate with xbee modules through labview serial(VISA). You may start with the Basic Read write serial example found in labview example.
steps:
open the example
connect the device th serial port
search the device port(com 1/com 2.. etc)
now you can transmit by writing to VISA and receive by Reading the VISA pellets.
.... and you are done!!!
i have worked on it, if you wish for a detailed description... i can help you futher.
regards
Message 3 of 8 (335 Views)
Hello SRI,THANK YOU for answering. The robot is wireless and a camer is to be fixed on the robot. How can i get the streaming video on the front pannal of the labVIEW?
       The components i am using are Arduino UNO and Xbee.how can i make it done ??
and what type of camera should i use?
     These are the questions running in my mind.....
PLEASE HELP ME IF YOU COULD.
Message 4 of 8 (335 Views)
Reply
Ganesha Moorthy Arunagiri Hello Ganesha Moorthy.THANK YOU FOR ANSWERING.
Message 5 of 8 (335 Views)
Reply
Dear Nihanth,
If that is the case you can`t transmit all the data`s of an image successfully in a xbee. There will be a loss of data (Pixels in a image).
In this case you can use an wifi module to transfer data which might result in prevention of loss of data.
Ganesha Moorthy
Message 6 of 8 (335 Views)
‎02-01-2014 09:01 PM
Hi Nihanth,,
Sorry I could not Reply.....
I am equally agree with Ganesha,, Xbee tranmission is always hampered by data loss, wifi will be a good sugesstion.
Regarding Connection with LabVIEW and Arduino UNO you can Use LIFA-LabVIEW Interface For Arduino Addon (FREE ).
For Image Acquistion and  display in LabVIEW front Panel you can use IMAQ/IMAQdx(Install Laest Device Driver for Vision Acquistion).
I'llbe happy if you could Please Update Your Project Status regularly.
Best Regards........
Message 7 of 8 (335 Views)
Reply
hello ganesh,Sri,
                     I am doing my final year project and this is the link of the video of my project, but they asked me to improve the project.
can you suggest me the ideas to improve this??
                     LINK: https://www.youtube.com/watch?v=62_4Eg25p4E
I just thought of replacing RF modules with XBEE, but uyou are saying that this will not be effective. So please suggest me.
Message 8 of 8 (335 Views)
Reply
