NI Home > Community > NI Discussion Forums
LabVIEW Developers Seeking Employment
Do you mean
Reply
Member
VI_Joe
CLD Traffic Light Sample Exam
I am posting my solution for the CLD Traffic Light Sample Exam.  Comments and input is appreciated.  The main VI is Traffic Lite.vi.
Thanks in advance.
Trusted Enthusiast
Re: CLD Traffic Light Sample Exam
Post in the LabVIEW board so that more people will look into it.
Active Participant
mtat76
I guess this is for whoever comes after, but since couldn't find an update to this post anywhere else.  First, the interface seems to be slow to respond.  This is because the event structure is located in the state handling loop.  You might want to consider placing the event handler in a separate loop that is used strictly to handle such interactions.  Second, you are using waaaaaaaaaay too much CPU - throttle that loop (10 ms should be fine).  Finally, consider using the elapsed time express sub VI instead of your own VI - this will save time and energy.
Hope this helps future CLDers.
Cheers, Matt
Matt Richardson
Certified LabVIEW Developer
MSR Consulting, LLC
Member
elkag
All great suggestions.  Thanks.
