NI Home
Cart Cart | Help
You are here:
Reply
Member
Rick K
What IP should we get on IPNet?
The goal of the LabVIEW FPGA IPNet is to allow FPGA users to get up an running quickly by using and learning about various functions or IP Blocks already available. These pieces of IP come from the FPGA product and tookits, DevZone, Community, Tools Network, or any number of other places both internally and externally. Some are free to download and tweak, while other are inside a product from NI or a third party. We are in the beginning stages of putting this site together and version 1.0 is live right now. We want it to be a very community driven initiative
The new LabVIEW FPGA IPNet is located at ni.com/ipnet
We are in the process of moving the content on this site to better place on ni.com which will have easier searching and features to increase usability. Therefore, we are not looking for lots of feedback about the way the page looks or formatting. I am opening this thread to get feedback and suggestions on what IP we should have on this site. Currently, this is clearly not a comprehensive list of all possible customer needs. We need to get input as to what the FPGA community is looking for on a site like this.
If anyone has thoughts, please speak up. Also, if anyone has FPGA functions that you developed and are willing to share with the community. Go to IPNet for instructions on how to quickly upload IP so that it can be linked from the page.
Rick Kuhlman | LabVIEW FPGA Product Manager | National Instruments | ni.com/fpga
Check out the new FPGA IPNet for browsing, downloading, and learning about LabVIEW FPGA IP Cores ni.com/ipnet
Member
Pawel_Reszel
Re: What IP should we get on IPNet?
Hello!
I found that in some future there should be FPGA FFT example on the IPNet.
Can someone tell me when should I expect that? I need FFT procedure that would be able to give about 2048 points spectrum at 10kHz sampling rate (FFT value every 5 Hz)
Thanks in advance for answer!
Pawel
Member
Vineet A.
I think I might know of a beta version that can be posted.  I'll find out and let you know.
Vineet A.
Member
Rick K
We have an FFT on the community now! It will soon be linked from the ni.com/ipnet.
The download has some examples included to help you get started. I hope this helps.
Member
momolxg
FFT on FPGA timing
Is it possible to give a benchmark frequency for FFT of 2048 16 bit arrays on a PXI7833R?
Also I would like to know how many channels it is possible to simultaneously FFT on a PXI 7833R.
Unfortunately not able to run LV8.5 on my FPGA for the time being.
Member
BIRA_PXI
SPI protocol
The SPI protocol IP is for LabView 7.0 Is there another one for LabView 8.x or can the SPI for LabView 7.0 used for LabView 8.x ? Also can this be used to write device drivers for existing Ni cRIO boards?
birapxi
Member
Rick K
The SPI protocol has been updated with an entirely new, more robust, and more scalable solution.
Member
madd
 Hello
 I need the viterbi decoder IP for different code rates e.g 2/3,3/4,4/5.... since give IP is a fix one with constrain length 7.
Madd
Member
Rick K
Thanks for the feedback. The one thing you can do is use the IP Integration Node and easily import the IP from the Xilinx Tools.
Member
madd
Hello
the requirements for xilinx ip required is labview 9 and Fpga Module 9 but i have both 8.6.1 version what now?
regards
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
